kfp673
Apr 21, 2015Explorer II
My concern (per my other post) is with the GMC auto level adjustment. The manual for the Yukon says you should allow the vehicle to level prior to adjusting the WD hitch. I think this is best so that the rear suspension is a bit stiffer however it is strange adjusting WD bars to a vehicle that is already level. Seems like you are lifting the vehicle even further. With that said, I guess the vehicle will adjust itself again if the rear end is lifted too far. Definitely need to read the owners manual as the different manufacturers seem to have different opinions.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
