BurbMan
Apr 21, 2015Explorer III
handye9 wrote:turbojimmy wrote:
EDIT: Just looked at my Avalanche manual. It says to drive 2 miles with the air suspension on before adjusting a WDH.
That's the same as 2014 Expedition. Ford says those two miles, need to be at 20 - 25 MPH.
How mamy people, do you suppose, are actually doing their two miles ?
It's not 2 miles every time you tow, only when you are "adjusting it". I would think that once you have the hitch dialed in, you pull up the spring bars to the same level every time. Most folks get into a camping "routine" of what gets packed where in both truck and trailer, so loading stays pretty consistent.
I would think that you follow the vehicle manual when initially setting up the hitch, and then assuming contact loading you return the WD to the same setting every time. I wouldn't think it would matter whether the air suspension came on before or after hitching once the correct settings are established.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
