lawnspecialties's avatar
Jun 19, 2015
We Need Some Shade
Where our camper parks, the western sun bakes the side. That side of the camper sits due west. Each trip we take, I alternate which way its parked to even out the time each side sits in the sun.
I don't mind getting a cover but during our racing season, we head out every other weekend. That's a lot of hassle and I know I'll probably not cover some times just because I'm too busy and don't feel like fooling with it.
Any ideas? If I do a screen, I'm afraid the first good storm will ruin that. The only idea that even pops into my head is using treated deck boards and making a louvered side. That would eventually match the boards of the barn but still give it a natural look. Louvers would keep it shaded but allow a breeze to flow through. Plus I just think it would look nice.
As far as we're concerned, we'll have an RV for the rest of our lives. So I see this as a reasonable expense for me; especially since so many RVs now are coming in colored sides.
  • I have a window wall on my stick N bricks that allows too much sunlight and heat in. I bought from PPL some heavy mesh shade screen for the end of awnings. It is very heavy stuff. Blocks 85% of the suns rays and yet lets light and air through. I attached this to a rail above at the roof line and then tie it off with heavy duty truck type bungee cords at the bottom. It can be easily rolled up and never is a problem in the wind. It's available in almost any color.
  • meganjoe wrote:
    When I first started reading your post the first thing I thought of was the 5/4" decking louvered.. Then I see you mention it further down.. I try not span more than 5' so the boards don't twist ..
    Joe
    Exactly. The posts now are 10' OC. I could run another smaller post between them to support the louvered boards.
  • When I first started reading your post the first thing I thought of was the 5/4" decking louvered.. Then I see you mention it further down.. I try not span more than 5' so the boards don't twist ..
    Joe
  • A canvas shop should be able to make up 4 panels for you to go between the posts. They could even include some flaps to bleed off effects of strong winds.
  • I would consider some sort of a vertical screen supported by the existing posts. Maybe some framed PE 4x8 lattice sections painted the same as the barn.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
