myredracer
Mar 28, 2016Explorer II
DrewE wrote:
It should be possible to grind it smoother with some appropriate tool. A sanding block (such as a convenient scrap of wood) and fairly fine carbide wet/dry sandpaper used wet, would be one reasonable approach. I have a couple of cast iron frypans with smooth ground interiors and one without, and I much prefer the smooth ones because they seem to stick somewhat less.
Of course, after any sort of grinding or sanding, cleaning and reseasoning is required. Cooking up a bunch of bacon helps the seasoning process along, and also good bacon is delicious.
I wonder why they make them rough if it makes food stick more? We have a cast iron frying pan that is relatively smooth. I do have a few pneumatic & electric tools that I could use to smooth the surface.
I did cook bacon first, thinking that would help but the eggs still stuck on like glue. Will try seasoning in the oven first before attempting any smoothing of the surface.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
