Lynnmor
Jul 14, 2019Explorer II
Retired JSO wrote:Lynnmor wrote:Retired JSO wrote:
Some hitches require the weight distribution bars to be removed while backing up at severe angles.
It is usually suggested that friction sway bars be removed, never heard of that for the weight distribution bars.
The people who sell them say it’s a good idea.
E-Trailer
Should Spring Bars Be Removed when Backing Up with a Weight Distribution System
Question:
Is there any issues with backing-up and making sharp cuts with weight distribution sway control RP66084 installed
asked by: Don D
Expert Reply:
With any weight distribution system you will want to remove the spring bars every time you encounter any tight maneuvering situation. So if you were reversing your trailer and the trailer did not swing too far to one side or the other you should be fine, but I still would recommend you disconnect the bars under most normal reversing circumstances just to be safe.
expert reply by: Jameson C
Jameson C
ASK THE EXPERTS A QUESTION >>
The RP66084 is a dual cam type WDH, not a friction sway control. There is nothing in the manufacturers instructions about removing spring bars prior to backing up.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
