myredracer
Jul 14, 2019Explorer II
The alleged "expert" at etrailer is wrong on the Reese dual cam 66084 WDH. Doesn't matter if you are moving forward or backing up, all the happens is the "crooks" in the ends of the bars ride up on the cams. There is friction between the bar ends and the cams which is part of how it works but the direction of movement has zero impact.
I would hate having to remove the spring bars before backing up and would mean blocking the road in a CG while you do that.
I have been backing up with our Reese DC for years. It can be quite noisy when going forward or reversing when doing tight turns and there'll be LOUD pop/bang sounds. Can be startling to people nearby! :)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
