BlunderLust
Mar 30, 2016Explorer
atwowheelguy wrote:
I'm curious about your truck's payload. Typically, the rating limit reached first is not the "towing limit", but is the "hauling limit". The tongue weight of a 12,100 lb. trailer (1200-1800 lbs.) combined with the weight of the passengers and cargo in the truck would exceed the chassis weight rating (GVWR) or rear axle weight rating (REAR GAWR) of most F150 pickups.
Your proposed 4400 "brochure weight" camper will likely be 6000 lbs. with options, propane, batteries, water, food, tools, outdoor chairs, etc. The tongue weight will likely be in the 720-900 lb. range.
I'm not looking at the vehicle right now but as I recall the cargo capacity is a bit over 2,100 pounds - 2,179 pounds comes to mind.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
