jerem0621
Jun 30, 2014Explorer II
Mr_MrsSchlepprock250 wrote:
Anyone have anything else to add?
Sure, you could always go with an EazLift 1400 with dual friction sway controls. It would do just fine with them. Reliable and proven and not 500-1000$.
Equal-I-zer and Dual cam are still friction sway control hitches they just apply the friction differently. A properly set up Traditional WD hitch and TWO friction sway bars with a properly loaded trailer and a properly loaded TV will handle as good as a Equal-I-zer (no real advantage over friction sway) and dual cam
Blue-Ox doesn't use friction to control sway it uses mechanical advantage and spring bar technology
IMHO the only real step up over a properly set traditional WD hitch and two friction sway bars is the Blue Ox... Next step is the Hensley twins.
Thanks and good luck!
Jeremiah
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
