Additional comments embedded below in red
bosworthj wrote:
I apologize in advance, I am going to throw a lot of info out at once for a pretty short question... So My wife and I upgraded from an 18 ft. travel trailer to a 26 ft. Fun Finder 265 RBSS. I have a GMC Sierra 2007 extended cab with the 3.73 rear end
Looked up your profile and it is a half ton....but there can be over a dozen different 'half ton' trucks offered by GM/GMC Best to list its GVWR & both GAWR, along with the GCWR in order for us to help you
and we are using a hitch system with a separate sway bar and the weight distribution bars are rated at 800#.
Without knowing the actual weight of the trailer tongue...800 lbs is out of context. See below need to know your actual tongue weight
The roads getting to the expressway around our house are a little rough, and I have noticed some "porpising" while towing. On the expressway I have also noticed a slight wag in the rear of the trailer from what I am seeing in my side mirror. It is never severe and always corrects itself. There have been some windy trips home that were a bit white knuckle though. The dealer setup the hitch and the guy said that he got it pretty level and was happy with it. He marked the chain link I should be using. Based on what I have read, it sounds like there might not be enough tension on my bars. My main question is though should I be messing around taking in a link when the guy that does this every day said to use the one link?
do not fixate on the dials/knobs/etc....all they are, are adjustments to to goal when finished adjustments. Have seen advisors run newbies in circles dialing in something that worked for 'them' and on that, just about every setup is different and there is no one size fits all...other than the goal for the final setup
That there is enough tongue weight (should be in the 12%-15% of the trailers ACTUAL weight).
That the trailer is level at it's highest pointing and IMHO prefer pointing slightly down
That you are within your OEM's ratings...assume you believe in them. If not, then academic this discussion. If yes, then gather your OEM's ratings info...go out and actually weigh the whole setup, axle by axle.
Then plug that actual info into the generic formula GCWR >= TV + Trailer + stuff.
Some more info: I got new tires last fall. There was a mixup and the tire place and they ended up giving me Load Class E tires. I was okay with that. I have been running them at 45psi which is what the truck calls for. They are rated up to 80 though I think, should I be running them higher?
Again, goes back to 'which half ton' you have. The higher rated GVWR will come from the factory with the next higher class tires that you now have. Regular half ton's come with passenager class tires (noted by a 'P' and you now have 'LT' or light truck tires)
The door label will list a tire class and size...that PSI info is for that tire. You no longer have 'that tire', but the next higher class tire and you have to figure out what PSI is best for you
LT class, load range E should NOT be run below 45PSI, IMHO. Unless they are flotation tires, which max out at 35PSI.
Weight of the gear and people in the truck is right around 700#. Dry weight of the trailer is 5700# and most of my gear is in the front storage under the bed at the tongue. It does have a rear kitchen though and an outdoor kitchen so I know the fridges are adding some weight back there. Fresh water tank is over the axels and while I occasionally pull with water in there I never pull with the gray or black tanks full.
Thanks in advance.
