skipnchar
Jan 27, 2014Explorer
I always recommend setting up your WD system to handle the trailer when it's FULLY loaded and NEVER at it's empty weight (dry weight). Your DOT safety plate will list the GVWR of your trailer and the spring bars should be a minimum of 15% of that weight (the heaviest your trailer tongue will ever be). Go as close to that weight as possible without being under it. Going too much (too strong) can result in a harsh ride and too light (too weak) can result in being unable to keep the trailer/truck stance correct AND create a bouncy ride when towing.
Good luck / Skip
Good luck / Skip
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
