Flyfisher410 wrote:
GCVWR is 13500. GVWR for the tow vehicle is 7350. Weighed in on CAT scales today and was 710 pounds over on the drive axle but 390 below max on the front axle. Trailer weighed in at 6200, each trailer axle is rated at 4000 pounds, dry weight is 6060 with additional cargo capacity of 1200 and change.
Will adjustment to the weight distribution hitch transfer extra weight off the rear axle?
I would try to take up an extra link if I were you. You might also be able to fuss around with the head angle a bit to transfer some of the weight, if you can't get another link.
For example, my trailer has 1200lbs of tongue weight and my front axle weight is within about 150lbs of my unloaded weight.
There are some good video online that will discuss how to properly setup/adjust the hitch.
