mkirsch
Nov 23, 2015Nomad II
hohenwald48 wrote:
In the initial post, the OP lists "TW Calc". How does one go about calculating the tongue weight if the trailer has not been weighed by itself and disconnected?
It seems that what the OP did was simply subtract the unhitched total TV weight from the hitched total TV weight. However, doesn't that ignore the fact that some unknown amount of weight is also transferred back to the TT axles?
The OP doesn't use a WD hitch, so no weight is transferred.
If you have the "no WD" weight and the "empty truck" weight, you can calculate the tongue weight by simple subtraction.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
