mowermech
Aug 11, 2015Explorer
A properly built trailer, towed with a properly set up tow vehicle, with proper tires on both, that is properly loaded with 12 to 15% of the GVW on the tongue, should not sway. If a "sway control" gadget will make the driver feel better, then one should be installed.
As for a WD hitch, if the front of the tow rig does not rise to the point where the headlights are blinding oncoming drivers when on low beam, it is not needed. If the headlights ARE blinding oncoming drivers, then the WD hitch is absolutely necessary!
The WD hitch is also necessary if the weight of the trailer takes too much weight off of the tow vehicle steering. I have read of that happening, although I have never experienced it.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
