BarneyS
Aug 30, 2004Nomad
Doug,
As I and many others tried to explain in your other topic, YES, you should be using WD with that trailer with that truck. Even at empty weight, your tongue weight will probably be over the rating of your hitch if you do no use the WD capability. I am not going to go over again all the reasons why you should use it as many of us have already done so on your other thread - just make sure you have your WD hitch and your rig set up properly and you should be able to tow without sway and in safety. In your last post on the other topic, you said you were going to try towing with the WD hitched up this weekend. How did that go?
Barney
Barney
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
