ffrnemtp
Aug 31, 2004Explorer
BarneyS,
I'll try to answer a couple of things here. No, I haven't been able to weigh anything yet because I may have to try to get the camper out of the path of ANOTHER hurricane. Towing with the WD bars on last weekend wasn't good--lots of sway. Instead of pulling the WD bars off I loosened them a bit and the sway improved slightly. Yes, a stock '04 F-250 sits a little higher in the back than in the front. We did front load the camper. Now I have a new problem--two Carlisle tires blew out on the trip--but that's another post. I'm going to check when I get home today, but I think my receiver is rated for 1,000 lbs without weight distribution, and I doubt my tongue weight is that much. The hitch was adjusted when it was moved from the F-150 to the 3/4 ton. I'm really starting to wonder if this trailer is ever going to tow worth a crap. It's pretty disheartening to struggle with sway and now repeated tire failures to no avail. That's the third Carlisle ST205 75R15 tire failure in less than 1,000 miles.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
