Ron_Gratz
Aug 31, 2004Explorer
--- If these quotes are incorrect and/or misleading then we need to face that and change the way we talk about tongue weight. We should not say that "the WD system distributes tongue weight."
Thomas,
Finally, we agree 100% on something. This is exactly why I proposed the definitions in Tongue Weight and Hitch Load - What are they and how are they different? and referred you to them in my very first response to you.
Part of quote from above:
"Yes, the WD system distributes tongue weight over both the front and rear axle (that is the purpose of it). "
I say this is misleading if that is not what happens. ---
I think this is an excellent example of how lack of definition leads to misinterpretation.
First of all, my dictionary's definition of "mislead" implies an intention to deceive. Given that definition, I do not think the statment is misleading, but I do think it is subject to misinterpretation. A reader easily could interpret this as meaning that a WD hitch decreases tongue weight. The same reader could believe that decreasing tongue weight can contribute to sway and, therefore, choose not to use a WD hitch.
Secondly, if I knew nothing about how a WD hitch operates, the statement would lead me to believe that weight is removed from the tongue and added BOTH to the front axle AND to the rear axle. We know this is not the case.
Thirdly, there is no mention of the fact that the WD hitch causes the load on the TT's axles to increase. This is fundamental to understanding how the WD hitch works.
So, please consider the following two statements:
1) The WD system distributes tongue weight over both the front and rear axle (that is the purpose of it), and
2) The WD system removes load from the TV's rear axle and distributes it to the TV's front axle and to the TT's axles.
Which of these do you think is the better definition (meaning less subject to misinterpretation) of the purpose of a WD hitch?
Ron
On Edit: I started composing this over an hour ago, but the ORF server was not responding properly. I did not realize that three posts had been received in the mean time.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
