freealfin's avatar
freealfin
Weight equalizer hitch
I have read all about these (50+ sites) but I question their ability to transfer weight any different than a hitch bolted to the bumper frame if the ball distance to axle remains unchanged. Both make the frame behave as a single lever regardless to were they are mounted. You could mount a rear hitch with long non flexing arms to the front of the frame and still won't change a thing...a single lever is a single lever. I do see the load carrying and pulling improving simply because bolts are on shear and on a stronger anchor point. Please enlighten me with your thoughts and not by simply repeating what someone else said.
Thanks.
  • DutchmenSport wrote:
    If you have doubts, try it. See what happens, and give us a report back.
  • Very simply put:
    Think of lifting a wheel barrow....the handles are similar to the spring bars of a WD hitch...they transfer some of the weight to the front wheel
    You said you didn't want to hear what others have already said... but this is what others have already said...it explains it and it's the facts...
    Weight Carrying
    When you're towing a trailer with a standard rear-mounted hitch, your trailer's tongue weight is transferred to the rear axle of your tow vehicle. As a result, the back end of the vehicle may be forced lower and the front end raised. If this happens, your vehicle's rear axle will bear the weight of not only the trailer, but much of your tow vehicle's weight as well. Less weight on the front axle of your vehicle can cause diminished performance in terms of steering, traction and stopping power. It can also increase trailer sway. And your view of the road may be limited due to the awkward angle.
    Weight Distributing
    Before and after weight distribution
    Weight distribution systems use spring bars to help combat the problems that often occur with standard hitch systems. Adding spring bars to your towing setup applies leverage to either side of your system, which transfers the load that is pushing down on the rear of your vehicle to all of the axles on both your tow vehicle and your trailer. This even distribution of weight results in a smooth, level ride, as well as the ability to tow at the maximum capacity of your hitch.
