marquette's avatar
marquette
Weight vs gas mileage?
I'm sure this question has been asked many times but I did a search and didn't find much. Looking at small TT the weight difference between 18-19 ft TT's and 21-22 ft TT's is about 800 lbs. 2600 vs 3400 lbs dry weight. How much will the 800 lb difference affect gas mileage assuming I add the same 7-900 lbs of cargo to each? I will be towing with a 1/2 ton Suburban, pick up or Expedition as I am not going to buy a TV until I find the TT so I know they are compatible. I'm assuming about half of the weight difference is that most of the 18-19 ft are single axle and the 21-22 ft are tandem axle. I know SA vs TA is a whole discussion in it's self.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
