AH64ID
Mar 28, 2014Explorer
I would drop the pressure to a more reasonable pressure and drive it empty a few times. The tires should break in with some heat cycles, city driving might not be bad as the speeds are lower and you get lots of corners.
A safe setting, unless you carry a lot of stuff in the truck, would be for 4,000 front and 3,100 rear. Assuming a 265/70R17 try 40 front and 35 rear for a few city drives and see what happens. Those pressures would be good up to 65-70 for short stretches, if you do lots of high speed then up those pressures by 5.
You will have to increase pressure when towing.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
