ExxWhy
Mar 29, 2014Explorer
DiskDoctr wrote:ah64id wrote:
I see max load and max pressure, what about at a load less than max?
Have a link for a lower load? On wait, I already posted that for you.
Yeah tires do have ratings, all you seem to care about is max. I gave you a link to a chart for loads less than max, made by a tire company and similar to many other tire companies charts, and you ignore it.
If this is how you are with tires I'd hate to see you react whe the fuel gage hits 1/2......
I would say it for the last time, but somehow I don't think it will get thru to you.
These are not MY opinions, all the data I am presenting is based on published data from vehicle and tire manufacturers. The only thing you are giving is an opinion, one that doesn't hold any water when presented with the facts.
Heck I even showed you the door jam sticker showing a 40 psi recommended pressure on an OEM LRE tires rated at 80 psi max, what more is there to comprehend? It's not imagination, it's fact pure and simple.
In your, and only your, opinion running a tire at a pressure appropriate for its load is under inflated if that's less than 90% of max. You are the first one I have ever read that statement from. It's NOT under inflated, it's called PROPER INFLATION.
Firestones issue was under inflation, but only because it wasn't enough air for the weight and NOT because it was less than 90% of MAX.
Quote: "The Commercial Vehicle Safety Alliance is currently exploring how to define underinflation for enforcement purposes. CVSA has already settled on a definition of a "flat" tire: 50% of the max cold inflation pressure stamped on the sidewall of the tire, e.g., 60 psi in a tire stamped for its max load at 120 psi inflation pressure."
Source: http://www.truckinginfo.com/channel/drivers/article/story/2013/07/what-exactly-constitutes-an-underinflated-truck-tire.aspx
FMCSA and CVSA and multiple DOT enforcement are pretty credible sources. Granted, passenger vehicles are seldom (ever?) cited for under inflated tires, so we have to look at the professional references.
Interesting article, too bad you quit reading once you saw the tidbit you wanted to see. Here's a quote a little further down the page. "DOT inspectors won't usually check tire pressure unless they suspect a problem, like the tire looks soft," Fisher said. "The problem is they have nothing to go by except what's stamped on the tire. To determine the proper inflation pressure of a tire, they need to know the temperature of the tire and the load on the tire. All that comes into play in determining the proper inflation pressure of a tire."
Article goes on to say this at the end. TMC and CVSA are still working on this, and a solution doesn't seem close at this point. But maybe this information can help you in a DataQ challenge. Is that 70-psi tire really underinflated?
Load & Inflation Table examples
Michelin 275/80R22.5
Steer 5,980 @ 105 psi; 6,175 @ 110 psi
Drive/trailer 4,770 lb single @ 75 psi
Bridgestone 295/75R22.5
Steer 5980 @ 105 psi; 6175 @ 110 psi
Drive/trailer 4540 lb single @ 80 psi
Goodyear 295/75R22.5
Steer 5,980 @ 105 psi; 6175@110
Drive 4,690 @ 75 psi
How about this?
Michelin Inflation
Or this
Goodyear Inflation
Or this
Bridgestone Inflation
Or this
Toyo Inflation
If you look starting on page 7 of the Toyo PDF, it gives the guidlines for determining tire pressure for your particular application. Starts with the door placard and goes from there to the inflation charts for your particular tire size.
The common denominator in all this is there is a specific PSI that is appropriate for various tire sizes and loads. Why would these tire mfgs publish pressure data that is dangerously under inflated? The answer of course is they wouldn't.
You may notice perusing the charts that each specific tire and size has it's own table. Some start as low as 35 PSI, some start at 70-75 PSI. It depends on the tire and load.
Nowhere in any of this do I see something that says use the max sidewall number when your load is less than the max capacity.
I will say this to the OP. You can follow the published guidelines or you can follow the random internet guy opinions. My OPINION is the published guidelines are the way to go.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
