goducks10's avatar
goducks10
What a bunch of junk.
From todays RV Business report
Report: ‘NHTSA’ Releases Latest List of RV Recalls
By: RVBusiness|Published on: Nov 18, 2019|Categories: Today’s Industry News|
The following is the latest list of RV recalls compiled by the National Highway Traffic Safety Administration (NHTSA).
• Airstream Inc. is recalling 1,888 2019-2020 Sport, Nest, Flying Cloud, International Serenity, International Signature, Classic, Globetrotter and Tommy Bahama trailers and 2020 Basecamp, Bambi and Caravel trailers. Due to improper welding, the Demco ball coupler installed on the travel trailers may not provide enough clamping force on the tow ball, potentially causing the coupler to separate from the tow ball.
• Thor Motor Coach (TMC) is recalling 378 2019-2020 Chateau 22B, 22E, 23U, 24F, 25V, and 28A, Daybreak 22GO, Four Winds 22B, 22E, 24F, 26B and 28A, Freedom Elite 22HE and 2020 Quantum GR22, and SE22 motorhomes. The seatbelt-unfastened warning light will not illuminate for approximately five seconds after the ignition is moved to the “on” or “start” position. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 208, “Occupant Crash Protection.”
• Keystone RV Co. is recalling 157 2019-2020 Crossroads Sunset trailers, model 242BH. The interior range cooktop is installed in a cabinet that may not be entirely sealed from the furnace cavity. As a result, during furnace operation, the interior range cooktop burner flame may invert.
• Forest River Inc. is recalling 41 2020 EVO, Salem and Wildwood travel trailers. The trailer cooktops were installed with a rubber liquid propane (LP) gas line instead of a copper one.
• Forest River is recalling 27 2020 East to West Delta Terra (model 312BH) and East to West Silver Lake (model 31KBH) recreational trailers. The overhead bunk fasteners may not be properly secured to the backer board of the bunk.
• Forest River is recalling 19 2020 Surveyor trailers, model SVT33KFKDS. A fuse of the incorrect amperage was installed for the 12V refrigerator, potentially allowing the wiring to overheat.
• Forest River is recalling 14 2017 Dynamax DX3 and Force motorhomes. The front axle stabilizer bracket may not properly mount to the axle, and may break as a result.
  • Those are pretty low numbers, once past the Airstream and Freightliner chassis issues.
  • These would be the Chassis MFG Recall not the RV builder.
  • Airstream looks like the wrong part was pulled, but everything else sounds like workmanship. Given these are new models, and not knowing the associate processes- I wonder if internal QA caught these, a safety inspector did, or the consumer experienced the issue and then the recall came through.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
