BurbMan
Jul 08, 2013Explorer III
I'll just re-post my answer to the same question you asked in this thread. Ask the question any way you like, the answer is going to be the same....do the math of what you are planning to carry and tow, and see what your capacity requirements are. No acronym is going to do the math for you. In fact, I already did the math for you.
Good advice and I'll try to help fill in the blanks...this model 2008 Rockwood 8313SS camper has a dry weight of 6501 and GVWR of 7784. Let's say the loaded weight is 7500 lbs. 7500 x 15% = 1125. Since 15% is on the upper edge of tongue weight ranges we'll assume that includes the hitch itself.
OP's signature says wife and 2 kids, so we'll estimate that people and cargo are 200 lbs each. 200 x 4 = 800 lbs. I believe that the factory sticker that shows cargo or payload capability already assumes a full tank of fuel.
So, 1125 + 800 = 1925 is the minimum cargo weight that you should be looking for. If you click the link above to the Ford website, there are number of 150's that will provide this level of cargo capacity and safely tow that Rockwood.
hmknightnc wrote:
Since you are buying a new TV and to ensure you don't end up with something on the edge or giving you poor performance I would recommend you do the following
- Look up your TT GVWR (not dry weight) and multiple that by 15%
- Count the number of people going traveling and multiply by 250
- Guestimate the amount of stuff you will have in truck
- add 400# for fuel and hitch
Add all of the above up and then look for truck with a door sticker payload/cargo capacity with that number or greater. This will get you truck that more than meets your needs for TT hauling.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
