JimK-NY wrote:
I cannot understand why so many of you spend so much on expensive compressors. I bought a $40 Slime brand from Walmart years ago. It stores easily since it is a little different shape but about the same size as a loaf of bread. It works fine to over 100 psi. Yes it is slow but I have only used it once to pump up a flat. Typically I just use it to adjust pressure with temperature changes or after months when an adjustment is needed. It runs off the cigarette lighter so I do not need a generator or a hook up.
Well, not everyone can work with a low power compressor such as that. Some need higher pressures, and some don't want to wait the inordinate amount of time needed to add air to their large truck tires. And, while it you say it goes over 100 psi, it most likely won't make it to 120 psi or more. Which means it won't work for people who need tire pressures higher than you do.
Different people have different needs. Why do you feel that everyone should do as you do? That what you should be a wondering.
