LarryJM
Apr 11, 2018Explorer II
rudderman wrote:
Seeing a few more TT models with UVW 3700 lbs; think that would be safe to consider? Hopefully I'm not being dense... just really don't want a new TV at this point. Thanks again
I guess you can call me a Debby Downer/Doubter, but with all the stuff you want to put into your Burb, it's 1/2T rating with a non towing rear gear ratio, along with wanting to tow in the mtns almost any full profile trailer IMO is not going to make for a pleasant or good tow experience. Not only the weight, but to wind drag is two big strikes against you and the only way around that is to consider some sort of low profile (hybrid/Popup) type trailer.
Just seems like you're trying to put that 10 or even 15lbs into your 5lb SOCK:E
Larry
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
