lawrosa
Apr 11, 2018Explorer
rudderman wrote:
Thanks for all the responses, I really do appreciate them.
Checked the door jam, GVWR 7400 lbs. Suburban is a 2014. Checked the RPO codes to confirm GU4, 3.08 axle ratio.
Trying to find a TT that can fit all 5 of us plus the family dog; really happy with the Suburban (until now) and would prefer not to upgrade the vehicle at this point. Probably once the kids get bigger, but right now they are preschool age. Found a used 2016 Forest River Salem Cruise Lite 201bhxl for $9500 out-the-door which sounded perfect... as much as I want to make it work, we would also plan on taking it into the mountains.
Thanks again, appreciate all the feedback!
Hmm thats heavy.. Not bad but it is a 7500 lb trailer.
Since you say you will tow in mountains you will need a trans cooler.
http://ww.forestriverinc.com/product-details.aspx?LineID=170&Image=5063&ShowParent=1&ModelID=2403#Main
You will be best off starting with this type of hybrid. You can sleep 8 and all will be comfortable.
tongue weight only 335 and unloaded weight 3415. GRV 4500 lbs.
https://www.jayco.com/products/travel-trailers/2018-jay-feather-7/17xfd/
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
