Tom_Barb
Jan 17, 2018Explorer II
MDKMDK wrote:
Just some more random thoughts. You can tow a new Wrangler 4 down, lock it up, and have the keys in your pocket. I know, because I do it.
Typical Jeep tires are probably much better quality and more reliable than any trailer tire, no matter how much you upgrade them. How many Jeeps do you see at the side of the road with a flat, compared to towables disabled by tire failures?
Have never had a problem turning with the Wrangler behind me. Always tracks well. Just use your mirrors and rearview camera.
I can have my Wrangler hooked up and ready to roll in about 10 minutes at a relaxed pace with nobody to help me, except to do a light check.
Trailers add weight to your GVWR (tongue weight) and GCWR (weight of the trailer itself) which reduces the overall capacity of your setup. They also need to be licensed and inspected in most jurisdictions. And probably insured separately from the Jeep and the tow vehicle.
You haven't said what you plan on using to pull your Wrangler. That might help us evaluate your options.
In the end, it's whatever you can afford, can pull with your tow vehicle, and feel comfortable with when driving it.
My random thoughts
We all know that trailers no matter what type come with the cheapest tire the manufacturer can get away with. So are you saying the jeep tire is any better than a light truck tire of a load range D?
You can tow your jeep locked up because you are not required to have the key in the ignition, we would need two sets of keys to do that. We could just lock our keys in the jeep I guess, :)
When you are running so close to your max gross load that a trailer will put you over. your probably too heavy to start.
Turning radius of the wrangler can be exceeded easily with the longer coaches, short ones not so much.
We've tow our jeep well over 75k miles, and like I've said we do it both ways, and I've yet to have the jeep break down while up on the trailer.
many of the boondocks camps we go to are pull in back out, or back in pull out. on the trailer, no problem, 4 down, ? Oh Well it's unhook time.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
