blt2ski
Jan 04, 2019Moderator
IMHO, an accident.t waiting to happen. Is someone that does not take the time me to figure out if the trailer is properly setup. IE us the for aft and side to side weight distribution correct. If not, you have a trailer that wants to sway!
If tire pressure on one side is say 20+ psi lower, again, you have a situation that can cause sway.
Is the trailer level to slightly nose down hooked up ready to go? If nose up, a potential to sway!
Are tires the same size, construction etc? If not, a potential for sway
Need i go on?
Good. If your trailer sways with.no bars of a.y sort, figure out why the EFF the trailer sways, fix cause, tow trailer....THEN add appropriate AS system to tow a ball/pintle hitch trailer.
Not sure how ma.my miles, over 100k probably, towing.g trailers of different sizes with no bars. The ONLY times I've had issues, is when one of the above was the cause of the sway. Fixed issue, easy relaxing towing.
This is not to say towing my TT was not.more relaxing with just a WD system, more relaxing yet with a dual cam....
My point, setup correctly is the key! If you.use a Hensley to stop sway, which it will, YOU.my friend, are an accident waiting to happen!
My 02, and then some on subject!
Marty
Need i go on?
Marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
