- drsteveExplorerDicor makes two types of caulk: self leveling lap sealant for horizontal surfaces like your roof, and non-sag sealant for vertical areas. And yes, the stuff on your roof did come out of a caulk gun. It spreads, which is what they mean by self leveling.
- JIMNLINExplorer IIIIf the sealant is tight don't try and remove it. If there is a hairline crack in the sealant simply I add maybe 1/16" thick over the crack area.
Sidewall edges.... as in roof edges ??
I've never had to add sealant on my 21 year old/32' roof edges on this camper however this unit has no exposed roof edges or scr heads to worry about it leaking. I did recaulk the rear cap to roof edge on one end.
Whatever brand of sealant you use be sure and follow its instructions to the T and watch their youtubes.. Also lots of youtubes available on the this subject....some from experts and some from not so expert. - luberhillExplorerAlso what do you use to caulk the side wall edges ? I assume that's done with a caulking gun but what caulk ?
Thx - luberhillExplorer
JIMNLIN wrote:
Just because its a sealant on the roof does not mean its Dicor.
Both large rv dealers near me say their trailer brands mfg uses several different brands of sealants that may or may not be a brand we buy in a caulking tube.
Only your trailer or possibly the dealer may know what type/brand of sealant is on the roof.
What you don't want to do is keep piling it on and make a dam for water to sit.
When resealing spots every 8-10 years I use Dicor
So do you cut all the old stuff off ?? This was factory done im sure, no way this came out of a caulk gun more like poured on - luberhillExplorer
donn0128 wrote:
White?
Dicor Self leveling lap seal.
Yes! After cleaning and removing any loose caulk
Well I ASSume it WAS whit but its black now, mildew ? none loose it looks tight, but thick and wide - JIMNLINExplorer IIIJust because its a sealant on the roof does not mean its Dicor.
When resealing spots every 8-10 years I use Dicor - Mickeyfan0805ExplorerAre you talking about the lap sealant? If so, the answer is yes. Clean excessive grease or dirt off the area (if needed) and then apply it to a dry surface. Just make sure you use the self leveling sealant if it is on the roof - there is a different form that doesn't level that you use for vertical surfaces. Many of us place lap sealant on top of itself year after year to cover cracks that are appearing.
- donn0128Explorer IIWhite?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
