donn0128
May 17, 2018Explorer II
The right way is option two. Connect open valve, open bleeder, start pump, when propane comes out of the bleed valve, close vslve, stop pump, close bleed, disconnect. The bleed valve is what is called an 80% valve. It is intended to allow liquid propane out at 80% of tank capacity.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
