wa8yxm
May 17, 2018Explorer III
The Bleed valve as you call it is the "Visual Overfill Indicagtor Device"
I have seen all sorts of claims about that valve like "You can't fill the tank if you don't let the air out".. There is no "Air" in the tank, it's full of propane gas.
There is a float valve that is supposed to cut off the inlet when the tank is 80% full. however like all mechanical valves IT CAN FAIL.
The "Spitter" valve as I call it (Visual overfill indicator) will clearly show when you hit 80% so the operator can close the fill valve and shut off the pump manually.
Oh and you left off a step
CLOSE ALL OUTLET VALVES FIRST.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
