bfast54
Jun 29, 2014Explorer
mgirardo wrote:bfast54 wrote:
I had the BLOWOUT,not, someone I knew who knows someone that they know..... it happened to me.....
That's not what a blowout is. You had a gash in the sidewall that caused your tire to go flat over a period of time. That's a flat tire. A blowout is when the tire rips open and goes flat instantly. It can happen for various reasons.
Yes a TPMS will alert you to a possible blowout situation. However, if you hit something on the road that causes the blowout, the TPMS isn't going to help you in that situation. It will let you know the tire is flat after the fact, but it won't alert you of an impending problem.
Funny,since it sounds like You SAW IT .........from your Description...WHY DIDNT You help me Change the Tire...:S
It was a SIDEWALL FAILURE..... Which BLEW OUT the Tire........
HOW IT GOT that way,is Immiterial.....:h
In actuallity,the BLOWOUT was bigger than an INCH..... but I did not measure it........:S
It WAS A CATASTROPHIC FAILURE of the Tire...Which Blew out a HOLE IN THE SIDEWALL....... and My T.P.M.S....... alerted me,so I could pull over,and Prevent Further Damage,to the coach,rim...etc....
Even if the WHOLE SIDE OF the tire BLEW OFF... the T.P.M.S...... will alert you INSTANTLY....OF loss of air......
If you are driving along, and the Rear Passenger side tire " Blows Out"..... are you saying you Will Guarenteed Know INSTANTLY?????????.....Without a T.P.M.S.???????????
Sorry, I dont buy that.!!!!!!!
Sounds like you are contesting the " Manner in which the Incident Occured"....When the important thing is......The Incident Did occur,and I had no Further Damage.....!!!!!!!
I will try to look up my Picture I took,on the side of the road, and you can Tell me, by a Picture...Just what happenedi.....over the internet for me.:S
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
