MFL
Feb 20, 2019Nomad II
You don't give your trailer loaded to go weight. In some cases people will be way over tired on their trailers, and would be better to air down a little from max pressure. If you have the proper load range tires for your trailer, I would run the max 110 psi. The weight on each tire can vary, so you would be good on all of them. IMO, it is best to use the proper load range tire, for your trailer, and max pressure. Many trailers come with barely capable load range tires, and in this case, I'd go one load range up, but still run max sidewall psi.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
