RoyF
Feb 20, 2019Explorer
I had one Sailun (G) tire on my fifth wheel for several years; the other three are load range F tires. Trailer weight 12,000 lbs, with 10,200 on the trailer axles. I just used 80 psi in all four tires. The tread wear pattern was about the same for all four tires, so the Sailun did not show signs of under-inflation.
You did not state how much weight your Sailun is carrying.
PS. The load range G tire was overkill for my trailer, but one time when I was on a trip and needed a replacement tire, and the only tire I could find locally was the Sailun.
PPS. After that blowout on a load range E tire, I have used load range F tires (and the Sailun until last summer) and have had absolutely no tire problems.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
