schlep1967
Feb 20, 2019Nomad
My opinion, may be wrong may be somewhat right. With the equaflex suspension on most trailers it is possible, under certain conditions, to transfer the weight from one tire/axle to the other. It may be only for a moment but it can happen. Think about what happens when you go over a speed bump. You can actually lift one wheel off the ground. (And you can actually buy ramps designed to do this for tire changes on the road.) At that moment the normal weight that two tires carries is transferred to a single wheel. Because of this, I feel better at max inflation pressure.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
