Lantley
Feb 20, 2019Nomad
JIMNLIN wrote:
The OP sig shows a 3270 Big Horn trailer.
Big Horn shows a 15500 gvwr with tandem 7k axles. At full axle load is 3500 lb load per tire.
The OEM tires show to be LT235/85-16 G which is 3750 lb at 110 psi.
The same size Sailun S637 ST235/85-16 G has a 4400 lb load capacity at 110 psi.
Industry experts including Goodyear rv tire tech website tells us to use max sidewall pressures unless it causes a harsh ride..... or balloons the tire. In case of a trailer that has been over tired these folks make good cents/sense.
rvsafety.com
Tire Load and Inflation Ratings
Note: Towable – Travel Trailer/ 5th Wheel owners Due to the severe use conditions experienced by tires when axles are very close together – tire industry experts recommend maximum (sidewall) inflation pressure for towable tires unless this causes a sever over-inflation situation (20psi+), often referred to as the ‘basketball effect’. If this is your situation allow a 10 – 15psi safety margin above the minimum required inflation pressure.***
Keep in mind mfg tire pressure charts are a minimum which work good for a truck with axle toward the corners but don't work the best on a high scrub tire on a trailer with close spaced axles like our rv trailers have.
Good info. Never heard the requirement to air up to the max expressed quite like that.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
