B_O__Plenty
Feb 20, 2019Explorer II
MarkTwain wrote:rbp111 wrote:
I have a trailer which has Sailun G rated tires. The maximum PSI of air is listed as 110 PSI. I was carrying 90 PSI but recently was told that the maximum PSI, that is 110 PSI is the amount of air I need to carry.
Which is the amount I should have in the tires?
Look on the side of the tire. The max PSI number is on the side. I run the max psi when I am towing and then run 65 non towing.
Why do you let the pressure down when parked? They still have to support the weight. I don't understand what there is to gain.
B.O.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
