Cummins12V98
Feb 21, 2019Explorer III
Lantley wrote:Cummins12V98 wrote:
Give GY Tech a call and ask them what to do when going from a "E" to "G" tire. They will tell you to use the chart and add 5psi.
Why do you think they make the chart? MOST RV's axle rating is determined buy the tires capacity at MAX psi.
E rated tires are rated 80 PSI max. Adding 5#'s will give you 85PSI.
I don't think 85 PSI gives me the maximum cargo capacity,ability, performance of a 110 PSI tire.
I prefer to skip the charts and go straight to the max. I do think it's a good idea to monitor the wear for the B-ball effect as mentioned in JIMNLIN's post above.
WHERE did I say anything about adding 5psi to an "E" tire???
I DID add 5psi to the chart for the "G" tires that made 85psi the correct pressure. Many thousands of miles with perfect tread wear and cool running even in temps North of 100.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
