Cummins12V98
Feb 21, 2019Explorer III
B.O. Plenty wrote:MarkTwain wrote:rbp111 wrote:
I have a trailer which has Sailun G rated tires. The maximum PSI of air is listed as 110 PSI. I was carrying 90 PSI but recently was told that the maximum PSI, that is 110 PSI is the amount of air I need to carry.
Which is the amount I should have in the tires?
Look on the side of the tire. The max PSI number is on the side. I run the max psi when I am towing and then run 65 non towing.
Why do you let the pressure down when parked? They still have to support the weight. I don't understand what there is to gain.
B.O.
He obviously mis read the post and thought the OP was referring to TV tires.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
