CALandLIN
Feb 23, 2019Explorer
rbp111 wrote:
I have a trailer which has Sailun G rated tires. The maximum PSI of air is listed as 110 PSI. I was carrying 90 PSI but recently was told that the maximum PSI, that is 110 PSI is the amount of air I need to carry.
Which is the amount I should have in the tires?
Are they the Original Equipment tires?
For original equipment tires the correct inflation pressure is displayed on the tire placard.
If they are replacement tires with the same designated size but a higher load range you can inflate them to the same PSI as the OEM tires or increase the PSI to a value not to exceed the wheel rating or maximum sidewall pressure on the tire.
If they are a 'plus sized" tire, the tire industry standard is to insure they provide, at the minimum, a load capacity equal to or greater than the the OE tires provided.
There is no provision in the standards to inflate tires to the load carried. That's an off-shoot of the FMCSA regulations and not applicable to FMVSS standards.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
