Fresno_Tundra_D's avatar
Apr 22, 2014
What the #@!! happened??
Recently while dry camping in Yosemite we had a problem arise. During generator hours my lovely wife plugged in her flat iron/hair straightener and the hair dryer at the same time in the GFI outlet in the bathroom. As I stood in the kitchen I thought I got just a hint of some electrical burning. I look under the sink and saw nothing but looked up and saw the microwave and coffee maker both not lit up.( No flashing 12:00) I plugged them both in directly into the generator and neither one worked. No coffee or microwave the last two days of our stay. We get home and I let the rv sit for a day and plug in to the house and now everything works fine. What happened? I thought her heavy electrical draw maybe damaged the micro and coffer maker even though they had not been in use. No problem with the fuses either. One more thing, all the outlets stopped working as well until I reset the GFI. Could the electrical wiring have been damaged? I thought the GFI would prevent that. I don't know. I hate electrical issues!!
  • RckyMtnVia wrote:
    Do you have a breaker on the converter or inverter? If so, they may have tripped. What about fuses?
    Ok, I'll check the converter. All the fuses in the fuse box in the rv are fine.
  • You need to open the RV electrical panel and using a screwdriver make sure all connections are clean and tight.
  • Do you have a breaker on the converter or inverter? If so, they may have tripped. What about fuses?
  • SPRING STREET wrote:
    Probably tripped the breaker on the Genny!
    Yeah I thought it might be the generator(Yamaha 3000iSEB)and I checked it. The overload light was not flashing and it seemed to be working fine. One curious thing though, when I plugged her blow dryer directly into the generator, the high speed worked on the blow dryer but not the low speed. Both speeds on the hair dryer work now at home.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 06, 2026
