sch911
Nov 10, 2015Explorer
mowermech wrote:
I disagree! IMO, it makes a very good case for loading your trailer (ANY trailer!) properly
Any sway control gadget is, IMO, a band-aid approach to the problem.
A properly built, properly loaded trailer, being towed by a proper tow vehicle, on proper tires, with proper inflation, simply should not sway.
IF there is any sway at all, the correct thing to do is find out why, and FIX THE PROBLEM. Trying to cover up a sway problem by using a "sway control" could very likely result in just what the video shows!
I don't think you understand the basic flaw in a TT hitch that actually causes sway. The hitch pivot point is well behind the TV rear axle. Look at the geometry of that and think about that, then look at a Hensley to see how to fix the flaw. Oh, and that's also why fifth wheel trailers have no inherent sway either.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
