fj12ryder
May 10, 2020Explorer III
Just to be clear about the EZLube system. You really can't overgrease the bearings with this system if it is working correctly. The grease will go in the zerk, through the rear bearing, through the front bearing, and out the front of the axle.
As to whether the EZLube system is really needed is a moot point, i.e. up for debate. If the bearings are greased properly, you don't really need to add grease until the next time they are checked. I was a proponent of the EZLube system, but have decided that it really isn't necessary. All JMO of course.
Looking for advice before your next adventure? Look no further.25,209 PostsLatest Activity: Aug 28, 2026
