Chuck_thehammer
Dec 28, 2015Explorer
Deb and Ed M wrote:Chuck_thehammer wrote:
I know and understand "Water" is millions of years old...
but what lives in water, or grows in water...
my reason... I am Healthy for 63 (No Med's).. but my wife is another story.. and she gets ill easily . and she takes about 10 pills a day..
I was a "Water Technician" (owned a pool/spa store) and your thinking is correct: stuff DOES grow in wet or damp locations. The most common bacteria is called pseudomonas: a bunch of it will make water smell "swampy", and if you run your finger on the inside of a water line, it will feel slimy. That's because pseudomonas secretes a slime layer to protect itself from dry periods and invasions, like chlorine ;-) It's why you should let the hose run briefly before using it to fill the freshwater tank - it will blow out any un-attached pseudomonas.
Even if you sanitize your tanks with chlorine, it's doubtful you'll ever kill everything growing inside the plumbing. While ingesting some bacteria won't bother most people - in the case of your wife's more fragile health - I would recommend using bottled, purified water for drinking. Go ahead and shower and cook with fresh-smelling tank water. Try to fill the freshwater tank with city (chlorinated) water when you can; or add a freshwater additive to well water. Bleach isn't always a good sanitizer because it has a very short shelf-life.
Thank you.. I now know more...
for now.. bottled water for her taking pills and boiled water for TEA.. during the day.. she drinks bottled Flavored water.
Thank You again...
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
