Hello again all! No, we are not in Alberta. We are in Osoyoos, BC which is where we normally winter every year. The temperatures here are warmer than Alberta and there is substantially less, if any, snowfall. Currently our daytime highs are in the 9 to 11 deg. C range (around 50 deg. F) and overnights are around the 32 deg F mark. Humidity is around 60 right now.
John&Joey: That is a nifty idea and certainly worth a try. Thank you for that.
We use a combination of both electric and regular furnace (propane) to heat the RV. I am fighting cancer right now and as a result of the disease and the treatment I need to keep the RV reasonably warm - not excessive, just at 70 degrees.
We will try to keep you posted with progress and fixes.
Cheers!
Mike and Carol
