- DKeppnerExplorerI've installed/replaced old sockets with these. No problems yet.
Car DC Digital Voltmeter/Dual USB 2 Port/DC12V Power Socket - hedgeExplorerSome of those ebay/amazon ones are complete crap. I went with blue sea stuff, it's spendy but better quality.
- Victory402Explorer
Victory402 I found it here-Ebay-Waterproof Dual USB Charger and 12V Heavy Duty High Power Socket, Dash RV Marine
Thanks Mommie. I'm actually more interested in the more residential style you have pictured from your first post. The one Lance uses.
Anyone know where one of these can be purchased? - Ron3rdExplorer IIILower the number, the bigger the wire (generally).
- Johno02ExplorerRight
- mommie53241ExplorerVictory402 I found it here-Ebay-Waterproof Dual USB Charger and 12V Heavy Duty High Power Socket, Dash RV Marine :)
the 12v outlet will just be used for a 12volt tv I believe we are going to use 14 gage wire better than 16 lower the number better the wire - Johno02ExplorerDepending on what you intend to use the 12V outlet for, Make sure that you wiring is sufficient to handle it. If possible, these should be on at least 14 or 16 gauge wire, and protected with an in-line fuse if possible.
- Tango__AE7UIExplorerWest Marine also carries these.
- slarsenExplorerAmazon has a variety of USB chargers with standard 120V outlets. I've bought two of them, they work very well.
- Victory402ExplorerDid you find exactly what you were looking for, the one in your picture?
If so, where? Thanks.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 09, 2026
