catkins
Mar 27, 2013Explorer III
You need to follow YOUR manufacturer's directions very carefully. Some require an engine warm-up to move the fluids, a specific gear shifting routine, placing in neutral and turning off but leaving the key in accessory position and pulling a fuse. READ UP on what is required for your vehicle. Don't guess as it could be very costly.:E
Requirements can vary from model year to model year. Works great but you must follow the correct directions. CHECK THE MANUAL!
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
