gotsmart
Apr 23, 2013Explorer
chili's trip wrote:gotsmart wrote:Sooboy wrote:
On our 2009 CRV, this means after every 8 hours of towing you need to start the vehicle and run through the pre-towing steps again, which consists of running through all the forward gear positions one at a time...stopping in NEUTRAL. It's critical that you NEVER shift from REVERSE to NEUTRAL and then proceed with towing. You MUST shift from DRIVE to NEUTRAL.
You're also not supposed to tow the CRV any faster than 65MPH, which (for us) is fast enough.
Bummer. There are no speed, time, or mileage limits for the smart
car.
I just read an article about problems the smart car has with tracking behind the motorhome. Owners have to use bungee chords to stop steering wheel from oscillating back and forth. Smart car is no longer recommended for towing by Motorhome Mag. Good luck
Jack H
Nice disinformation campaign. I have posted that I use a bunjee because the smart car does not track well in the logging truck rutted highways of Washington State. The car is not wide enough to track IN the ruts. On other roads it tracks fine without a bunjee on the steering wheel.
fyi - the flat towing instructions are in the 2013 smart owners manual. My guess the reason why is it is not in the towing guide is that too many smart owners towed their car without following rule #1: Disconnect the battery when flat towing. RVers have dragged their smart cars on the rims because the brakes locked. Others have burned the engine and tranny because they towed it in park. A smart car replacement engine and tranny can cost more than the car is worth.
Except for the steering, the car is drive-by-wire. The transmission is controlled by the computer, not the shifter. The warnings at the bottom of the flat towing instructions say that if the car's computer is awake during flat towing, bad things can happen. Below is a direct quote from the 2013 owners manual:
Do not flat tow the vehicle with the front axle raised. Doing so may cause serious damage to the brake system which is not covered by the smart Limited Warranty.
Failure to follow the recommendations for flat towing can cause damage to your vehicle:
>Not following the battery disconnect procedure in the proper sequence may result in data loss in the vehicle’s control units.
>Not disconnecting the battery and leaving the key in starter switch position 1 (ignition on) may result in
- the vehicle locking. The vehicle will lock if the wheels are turning at vehicle speeds of approximately 8 mph (14 km/h) or more.
- the ESP® being activated. Active braking action through the ESP® may seriously damage the brake system which is not covered by the smart Limited Warranty.
>Not moving the gear selector lever to neutral position N may result in significant transmission damage.
>in a discharged battery.
Solution: A $15 marine battery switch. Guess where the battery is in a smart car? It's in the floor of the passenger side.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
