dodge_guy
Dec 03, 2013Explorer II
I f I was to do it I would do the front axle. when you brake the trailer will tend to pull the front of the trailer down which will tend to put more weight on the front axle. Yes I know the equalizing pivot on the spring should keep the weight even on all axles, but I still think the front axle will have the most weight, even if it is 50lbs more! and you will not have snow piling up in front of the locked front wheels if you chain the middle or rear axle!
Good luck and be safe!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
