RRTom's avatar
RRTom
Which tow package?
Setting up a 2013 Honda CR-V for towing. We got a quote from Camping World and a local RV supply/repair shop that has been in business for at least 15 years that i know of. We have a Demco tow bar so just need the tow bracket on the Honda.
The differences between the tow packages
Camping World:
Fusemaster so I don't have to remove the fuse every time we tow. Just flip the switch
Demco Stay In Play Duo braking system so I won't have to put the braking unit in and out every time I tow
Local Shop:
Charge line so I wouldn't have to pull a fuse
RVI 3 Braking system I would have to put the braking unit in and out every time I tow. Also comes with a tablet to view info inside the MH while towing. Also could be used to view other products that can be added later, such as tire pressure monitors.
Pricing is about $450 less at Camping World. By the way, got a quote from the RV dealer. I just laughed at that one.
Any thoughts on which way to go?
  • BTW CW sounds like a reasonable option. Do a careful online review of any shop.
  • Depends upon your camping style. Occasional camping then box brake, switches, rigid tow bar may be OK. But experience is a great teacher.
    We've moved up the ladder to easy to attach/detach tow bar, no aux brake parts to move, no switches etc, just plug and play. 6 wire electrical cord includes charge line AND wire from the brake lights to a MH cab light ie independent verification that the toad brakes are engaged.
    BTW My first toad was a 1500 lb VW bug that I had to lay on the ground to attach the rigid tow under the car to the front axle. That got old very quick.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
