stevekk's avatar
stevekk
Who all tows a Mini Cooper, all 4 down?
I have a chance to buy a used 2006 with a 6 speed/ TURBO/ 47000 miles.
But when I research the present and past towing guides from Motorhome Magazine, I question whether they can be towed all 4 wheels down?
I just talked to someone that has a 2005/ 5 speed and has towed it 60,000 miles w/ no problem.
He justs puts the key in the ignition, so the steering wheel free wheels and tows.
So...Can I, or can't I?
Or.. The good or the bad?
Why don't they say you can tow?
Does it have to do with lubrication to the trans-axle?
Whats the negative over the long haul?
THANKS..
I am new to all this..:h
  • You should have no problems.
    But, if it's an 06, it's supercharged, not turbocharged. ;) Also, the 06 still has a locking steering column so you'll have to leave a key in the ignition.
  • We started towing a 2008 clubman S 6 speed last season with a roadmaster base plt towed 2500 miles last season so far so good.
  • I helped a friend install the baseplate on his Mini Cooper S; he's towed it for several years with no issues.
  • what does the vehicle owner's manual say. that would be my first cut, before motorhome magazine. since they evidently say No, do you feel lucky?
    bumpy
  • I tow a 2nd gen manual transmission Mini Cooper behind my motorhome using a readily available Blue Ox baseplate. It tows beautifully, and I've never had a problem towing it. Mini, however, recommends that it not be towed. I suggest you do a search on this site, and you'll find several people that are towing the Mini Coopers without issue. Since the particular model that you're looking at is likely out of warranty you don't have to be concerend about Mini.
  • ..I must preface this by saying I have no specific experience with flat towing a mini cooper, can only speak from what I've heard from various places. Could be totally wrong, but...
    The fact that its a manual tranny, means towing it 4 down may well be possible, without hurting the drivetrain. Many manual tranny vehicles can be towed that way.
    However, IIRC the challenge with the Cooper Minis is in finding a way to attach a tow bar to the front of them. Not that many base plates available for them, as many Cooper Minis don't have anything solid enough in the front to attach a base plate to.
    Before buying the Cooper, contact Blue Ox (or maybe Demco and/or Roadmaster), see if they make a base plate for it. If not, I would ask the guy who said he tows a Cooper Mini, where he got his base plates, or how he attaches a tow bar to the front? Maybe he knows of someone that custom fabricated him some base plates?
    (..Maybe someone that owns a Cooper Mini will chime in, and correct me if I have mis-spoken?)
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: Jul 05, 2026
